Northrop F-5F
Product ID: 80-4694
Overview
Skill level: 3
Scale: 1:48
Length: 328 mm
Wingspan: 180 mm
Parts: 70
Description
They call themselves the “Top Gun” squadrons. Their slender aircraft skim through the sky and seek out their target. They fly, fight and think like Russian pilots and it is their mission to train the US Navy and Air Force pilots in how to hold their own in air combat against an enemy. These squadrons are equipped with high performance aircraft such as the F-5F Tiger II. This 2-seat fighter is capable of reproducing similar flying characteristics to the fighter sused on the Russian front and therefore of simulating their tactics and operational methods.
Model-details:
– Structural details on surfaces
– Detailed 2-seat cockpit
– Detailed instrument panel
– Cockpit canopy optionally open
– Detailed landing gear
– Auxiliary tank,gun pod
– 2 Sidewinder guided missiles
– Access steps
– Decals for one US Navy and one Thailand Air Force version
F-4F Phantom JG71 50th Anniversary
Product ID: 80-4685
Overview
Skill level: 3
Scale: 1:72
Length: 271 mm
Wingspan: 162 mm
Parts: 103
Description
The Phantom F-4E/F is still regarded as the workhorse of the western air forces. In addition to use as a fighter, in the German air force the Phantom has a second role as a tactical combat aircraft. Nowadays the operational Phantom only flies where it all began, with Fighter Wing 71 “Richthofen”. There where in 2009 the anniversary was celebrated appropriately to its status – with a specially designed livery on an F-4F “50 Jahre JG71”.
Model-details:
– F-4F front segment
– Detailed cockpit with instrument panel
– Detailed pilot seats
– Structural details on surfaces with recessed panel lines
– 2 auxiliary tanks
– Countermeasures pod ALQ 119
– Super decals with JG71 markings
– 4 AIM 9 L Sidewinder guided missiles
– 4 AIM 120 AMRAAM guided missiles
A-10 Thunderbolt
Product ID: 80-4687
Overview
Skill level: 5
Scale: 1:48
Length: 338 mm
Wingspan: 374 mm
Parts: 165
Description
The A-10 is still one of the most successful combat aircraft for close support/ground attack missions and can carry up to 8 tonnes of weapons. It received the nickname “Flying Cannon”. In fact the A-10 was designed around one of the most powerful American cannons – the General Electric GAU-8A Avenger – a seven barrel rotary Gatling gun. The whole system, built as a single unit with barrels and attached ammunition tank, weighs 1830 kg and is 6.4 m long. It carries 1174 calibre 30 mm shells each with a weight of 700 g. The pilot sits in a 408 kg titanium “bathtub”. The A-10 is a robust and powerful weapons system for ground attack with very limited electronics. However it was missions in Kosovo and later in the various warlike confrontations in the Gulf region on which the almost legendary reputation of the A-10 was founded. Its performance potential was further enhanced by later modification programmes to its improve its combat capability.
Model-details:
– Surface structures with filigree details
– Detailed cockpit
– Pilot figure
– Separate air brake flaps
– Access steps
– 11 pylons for external loads
– ECM pod
– 6 Maverick guided missiles
– Auxiliary tanks
– 8 bombs
– Decals for 2 USAF versions
Dornier Do335 Pfeil
Product ID: 80-4686
Overview
Skill level: 5
Scale: 1:48
Length: 291 mm
Wingspan: 290 mm
Parts: 81
Description
The Dornier Do 335 was the fastest propeller driven aircraft to be mass-produced during the Second World War. It represented a brilliant concept for a multi-role combat aircraft in which for the first time all the requirements had already been planned during the design stage. The tandem arrangement of the engines and the well-considered aerodynamics gave it a maximum speed of 763 km/h. The first flight took place on 26th October 1943 in Friedrichshafen, when the Do 335 demonstrated its superior speed combined with very easy handling. The Do 335 was one of the few operational aircraft equipped with an ejector seat – a feature only found in German aircraft. For pilot training a two-seat Do 335 was designed which – with suitably equipment – could also be used as a night fighter. At the end of the war numerous Do 335’s in varying conditions of completion were seized by the Allies in Oberpfaffenhofen, only one of which still exists today.
Model-details:
– Contains parts for the single seat version A-1 or the two-seat version A-12
– Inside engine compartment visible with simulated engine
– Detailed cockpit
– Separate flaps on wings
– Movable propeller
– Detailed undercarriage
– One pilot figure and 2 mechanics
– Decals for 2 German Luftwaffe versions
Stearman PT-13D Kaydet
Product ID: 80-4676
Overview
Skill level: 3
Scale: 1:72
Length: 105 mm
Wingspan: 132 mm
Parts: 29
Description
The Stearman Kaydet was the standard aircraft used by the US Army and Navy for basic flying training during the Second World War. Thousands of American and also Allied pilots were trained on this type of aircraft. It was nicknamed the “Yellow Peril”.
Model-details:
– Detailed radial engine
– Movable propeller
– 2 pilot figures
– Decals for one US Navy version
Gloster Gladiator Mk.1
Product ID: 80-4683
Overview
Skill level: 3
Scale: 1:72
Length: 116 mm
Wingspan: 137 mm
Parts: 33
Description
This single-seat biplane fighter flew for the first time in 1934 and was in service with 30 RAF squadrons. It played an important role in defensive battles over Norway, Malta and Crete.
Model-details:
– Structurally detailed surfaces
– Pilot figures
– Radial engine
– Movable propeller
– Decals for one RAF version
http://www.revell.com/
