Monogram 1/35 M48A2 Patton Tank Plastic Model Kit
Product ID: 85-7853
Overview
Skill level: 2
Scale: 1/35
Length: 9-7/8″
Parts: 152
Description
The M48A2 Patton tank was named for General George S. Patton, famous tank commander of World War II. It is a heavily armored, full-tracklaying combat vehicle with a 90 mm gun, a .30 cal. machine gun in combination mount and a .50 cal. machine gun in the commander’s cupola. Opening and closing hatches, movable turret, cannon, machine gun and tank treads. Two crew members and six military figures. Decals with optional markings. Molded in olive drab with soft black treads.
Fai clic per accedere a 85-7853.pdf
MAN 7t milgl
Product ID: 80-3179
Overview
Skill level: 4
Scale: 1:72
Length: 120 mm
Parts: 127
Description
For the movement of supplies to troops on the battlefield, the Federal German Army uses high mobility off-road vehicles. At the end of the nineteen seventies MAN introduced the “Lkw 7 t mil gl” which, due to its all-wheel drive (6 x 6) and free-moving axles meets the requirements and is therefore one of the best trucks of its class in the world. With its 320 bhp V8 engine it can reach a maximum road speed of 90 km/h. This model kit with 127 individual components contains a detailed reproduction of the transmission and axles. Other quality features include the finely engraved driver’s cab with true-to-scale internal fittings and the platform with authentic surface details. The tilts can be fitted optionally. The decals give a choice between 3 Federal German Army versions.
Model-details:
– Finely engraved surface details
– Authentic chassis
– Detailed transmission and axles
– True-to-original tyres and rims
– Detailed driver’s cab and internal fittings
– Platform with finely engraved surface detailing
– Separate tilts
– Fuel can
– Spare tyres with mounting bracket on cab
– Authentic decals for 3 Federal German Army vehicles
German Half-Track L4500R “Maultier”
Product ID: 80-3091
Overview
Skill level: 5
Scale: 1:35
Length: 224 mm
Parts: 419
Description
During “Operation Barbarossa” in the Soviet Union, in the first winter of war in 1941, the German High Command realised that the traditional truck was not suitable for the harsh climate and terrain. The vehicles often got stuck in the deep snow. In order to solve this problem, in 1942 the “Maultier” (mule) was developed. It was a variation on a production truck, on which the rear axle was replaced by a caterpillar track. From 1943, Daimler-Benz produced a half-track based on the all-wheel drive L4500R with the tracked assembly of the armoured fighting vehicle PzKpfw. II. The vehicle designated L4500R had a load carrying capacity of 4.5 tonnes. The model kit has attractive filigree and finely detailed components, including an authentic representation of the wood grain on the platform. In addition the model has a detailed reproduction of the engine, 2 figures (mechanic and driver) and an injection moulded track with individual links and sections. There are decals for 2 German Army versions.
Model-details:
– Detailed finely engraved surfaces
– Platform walls with authentic wood grain
– Detailed track running gear from PzKpfw. II
– Injection moulded tracks with individual links and sections
– Authentic reproduction engine
– Bonnet can be shown open
– Detailed internal fittings
– 2 figures (mechanic and driver)
– Authentic decals for 2 German Army vehicles
8.8cm Flak 36 mit Sd.Ah.202
Product ID: 80-3174
Overview
Skill level: 5
Scale: 1:72
Length: 90 mm
Parts: 200
Description
The 8.8 cm Flak, with a legendary reputation for anti-tank warfare, was a German anti-aircraft cannon used in the Second World War. Three versions were developed, the 8.8 cm Flak 18/36/37 which came into use on all fronts. At times up to 11,000 guns were operational and formed the backbone of the air defences against bombing raids. The maximum vertical ceiling was 10.6 km, the range 14.8 km. They could fire about 15-20 rounds per minute. In order to represent a Flak battery the model kit comprises the fire director 40 complete with trailer Sd.Ah.52. This piece of equipment served to ascertain the firing data. The Flak can be built in either the firing or the travelling position. The trailer Sd. Ah.202 is included and the outrigger gun mount can be folded up like the original. The gun elevates and traverses through 360�.
Model-details:
– Finely detailed surface structures
– Special trailer 202
– Fire director 40 with special trailer 52
– Elevating cannon barrel
– Build optionally in firing or travelling position
– Choose from 2 each protective shields and gun barrels
– Detailed outrigger gun mount with movable arms
– Stabilizers
– Authentic decals for 4 versions
http://www.revell.com/
