1/72 AH-6 Night Fox
Product ID: 017
Overview
Type: Transport and observation helicopters
Period: Vietnam
Country: United States
Skill: 2
Model Dim.: 13,6 cm
Box Dim.: 258 x 162 x 38 mm
Description
This small and easy-to-handle helicopter, developed in the sixties, proved to be a big technical and commercial success. Its reliability and performance make it a valuable aircraft for civilian and military operators of at least fifty different nations. This particular version derives frome the model 530 Defender and is in service with the U.S. Army Special Forces which use it for reconnaissance and night surveillance thanks to an infra-red night vision system, which together with the helicopter’s low noise level make it a perfect and silent “Night Fox”.
1/72 Ju-52/3 m “See”
Product ID: 1339
Overview
Type: Cargo
Period: Second World War
Country: Germany
Skill: 3
Model Dim.: 26,2 cm
Box Dim.: 345 x 242 x 48 mm
Description
The JU 52, nicknamend «Aunt Ju» or«iron Anne» because of its sturdy qualities, had a long and glorious career in Germany and many other countries. It was the Lufwaffe’s trasport aircraft during the entire course of World War it, was widedu employed in its seaplane version and played a paramount role in the campaigns in Norway and the Mediterranean. The most important chapter of its wartime career, however, was without doubt the landing on the island of Crete.
1/72 F-16 ADF/AM “Special Colors”
Product ID: 1337
Overview
Type: Fighter aircrafts
Period: Modern
Country: Italy
Skill: 2
Model Dim.: 20,9 cm
Box Dim.: 290 x 190 x 45 mm
Description
SUPER DECALS SHEET FOR 3 VERSIONS
In 1986, the USAF established the ADF (Air Defence Fighter) program in the course of which more than 270 F-16A/B Block 15 aircraft were upgraded to Block OCU aircraft and modified for the ANG departments. These planes had improved avionics and could be used with semi-active AIM-7 Sparrow radar-guided air-to-air missiles. The Italian Military Aeronautics Division leased 45 thousand hours of flight-time, between 2003 and 2010, for thirty F-16 Block 15 ADF aircraft upgraded to standard “Falcon Up” aircraft, and four F-16 Block 10 aircraft of converted operation. The work began on 28 June 2003, with the first F-16 landing at the Sicilian base, and on 22 May 2008 the aircraft of the 37th formation cut down 30,000 hours of flight-time.
1/72 Jas 39 Gripen (Model Set)
Product ID: 71306
Overview
Period: Modern
Country: Sweden
Skill: 2
Model Dim.: 19,5 cm
Description
– THIS PRODUCT IS SUITABLE FOR CHILDREN OVER 8 YEARS OF AGE –
– ACRYLIC PAINTS, LIQUID CEMENT AND BRUSH INCLUDED –
The JAS-39 is the new Swedish multi-role fighter presently being delivered to the Air Force. It is under serious consideration by former East-bloc countries, South American countries and others. It is competing against the Rafale, the Eurofighter Typhoon and the American F-16s and F-18s of the most recent design.
1/72 Mig-29A Fulcrum (Model Set)
Product ID: 71184
Overview
Period: Modern
Country: Russia
Skill: 2
Model Dim.: 23,6 cm
Description
The first prototype of the MIG-29 was first flown in 1978. The plane became operational in 1984. The fighter is armed with one 23 mm rotary cannon plus two R60 Aphid or A-11 close-range anti aircraft missiles and four Apex or AA-10 medium range missiles.
1/48 A-10C “Blacksnackes”
Product ID: 2725
Overview
Type: Bombers and reconnaissance aircrafts
Period: Modern
Skill: 4
Model Dim.: 33,8 cm
Box Dim.: 373 x 241 x 96 mm
Description
SUPER DECALS SHEET
This large twin-engine plane was built for the U.S. Air Force for troop support and anti-tank missions. Despite its extensive amour and armament the A-10 is highly maneuverable which is particularly important to overcome enemy anti-aircraft fire. The Thunderbolt (also called “Warthog”) was practically built around its remarkable 30 mm gun GAU-8, which can perforate tank amour with its special high performance ammunition. The aircraft was widely used during the Gulf War, where it successfully destroyed a few hundred Iraqis vehicles with minimum losses despite the heavy enemy defense of conventional and missile fire power. A.10 Around the mid-2000s, the A-10, updated to “C” standard, has been improved to be in line with the changed and evolved operational needs. The A-10C is, in fact, the most modern version of the robust and reliable strike aircraft able to use the most advanced weapon systems and target acquisition pods.
1/32 F-104G/S Starfighter
Product ID: 2502
Overview
Period: Modern
Skill: 5
Model Dim.: 52,1 cm
Box Dim.: 560 x 280 x 115 mm
Description
100% NEW MOULDS
FINELY ENGRAVED RECESSED PANEL LINES AND RIVETS – FULLY DETAILED ENGINE , COCKPIT , AND AVIONICS BAY – GUN BAY WITH FULLY DETAILED M61 GUN – OPEN OR CLOSED AIR BRAKES – PHOTOETCHED FRET – 316 PARTS – 2 HUGE DECALS SHEETS FOR 10 VERSIONS – INSTUCTIONS SHEET WITH COLOR PROFILES (10×4 plates) – (PRM) PHOTOGRAFIC REFERENCE MANUAL
The supersonic interceptor aircraft F-104 Starfighter was, without doubts, one of the most famous, and long-lasting, aircraft in History. The F-104 entered in service in the late ‘50s and served with USAF for a long time. Later on, it has formed the fighter squadrons of several NATO air forces for more than 40 years. The “Starfighter” was based and developed on an original and unique concept for its time : innovative shape of the plane extremely thin, small, straight mid-mounted, trapezoidal wings, the stabiliator mounted atop the fin, a powerful and reliable General Electric J-79 turbojet engine able to guarantee outstanding supersonic performances. The F-104G, manufactured under license in several NATO countries, has been built in a huge number of units and used, thanks to its increased flight range and load capacity, as multi-role fighter-bomber. The F-104S, upgraded in technological features and weapons system, has equipped the Italian Air Force fighter squadrons until the mid-2000s, replaced with the Eurofighter Typhoon, showing an impressive operational life.
